restoring Farm-all super C
eric johnson
07-14-2005 10:55:26
hi all i am new here to the forum so please bare with me if this question was asked already
my uncle as a farmall super c (not sure what year it is)and i am going to be talking to him about restoring it to running and show order but i need to know where to look for the serial number so i can figure out when it was built so i can get the right stuff to restore it this will be my first but hopefull not last project as my uncle has a farmall 400 that he uses to work on the farm and att it needs is a paint job and some decales any help would be gratefull
Hawkeye
eric johnson
07-20-2005 10:37:31
 Re: restoring Farm-all super C in reply to eric johnson, 07-14-2005 10:55:26
acctually nat there is a decale that says super c on the left side of the engine cover but would that mean anything???
Nat
07-14-2005 14:20:07
Even if you can't find the serial number, most parts are interchangeable from year to year. All you need to do is say it's for a Super C, if in fact that's what you have.
El Toro
07-14-2005 12:37:06
Once you get that SN you can click on serial numbers under Research & Info to your left.
You should get yourself a shop manual too.
Those Super C's are nice tractors. Hal
FC
07-14-2005 11:00:05
eric - the serial number should be on a plate attached to the right side of the tool box under the seat. (right side when sitting in the seat) It should be an aluminum plate with stamped lettering/numbering.
