460 Diesel, Pump Timed and Purring Loudly
Ron Smith
07-14-2005 19:31:34
Found that magic timing mark tonight and finally got the 460 running like a champ. Powers up real nice. Thanks for all of the help and excellent advice here from JakeF, Jimmy King, Bob, Aces, Brian in NE and others. I sanded the main pulley and found two lines on the damper about a half inch apart (no numbers or markings otherwise). On the first round, I timed it 180 degrees off. The second round, I hit the right spot and she took off with just using the starter, no pulling. Smokes and sounds really good. Harold was glad to hear her go; he bought the tractor new in the early 60s. He powered it up and listened real close. Have a few issues to work out with the voltage regulator, etc. Thanks again.
Jimmy King
07-15-2005 01:44:12
 Re: 460 Diesel, Pump Timed and Purring Loudly in reply to Ron Smith, 07-14-2005 19:31:34
Ron, I'm glad you got it running that 236 and the 263 are the smooth'est running engs made when right. I have been there and done that 180 out, will start by pulling, but no power at all.
