460 Injectors
720D
07-15-2005 14:13:12
I just bought a 460 Diesel and think I think that I have a injector that is bad. Is there some where that I can send them out to, to get repaired or rebuilt? Thanks Tim
KYTomcat
07-15-2005 19:23:00
 Re: 460 Injectors in reply to 720D, 07-15-2005 14:13:12
Before you jerk the injectors out and have them tested which could be almost the price of a new ones, try this. Get the engine running and loosen the fuel line nut at the injector. If the engine loses rpm and misses badly then the injector on that cylinder is good. If, after testing all of them this way, you may find the injectors are not to blame, but probably bad valves. These are hard starting engines and the heavy use of starting fluid will destroy the valves. good luck
caseyc
07-15-2005 14:21:58
any respectable diesel shop should beable to fix them. call your local case-ih dealer and find out who they send their pumps and injectors to. just had my 766 injectors gone through for $25 each. my local shop is DK Diesel, Watertown, SD (605)886-2750.
casey in SD
RustyFarmall
07-15-2005 14:17:30
Pick up your phone book and look at the yellow pages, should be able to find a shop not too far away.
