H mystery
new guy at trac
07-16-2005 21:03:36
my 48 H starts fine, runs for about 3 minutes at idle and quits as if you shut the mag off. I"ve gone thru the carb and fuel system, what about the mag? any suggestions?
PeteNY
07-17-2005 06:41:22
 Re: H mystery in reply to new guy at tractors, 07-16-2005 21:03:36
Sounds like you may have a bad coil.
El Toro
07-17-2005 04:09:12
Clean those points and set the gap at .013". New points and condenser may be in needed. When it quits check for fire at your plugs, should be a hot spark. Hal
FarmerSid
07-18-2005 04:04:05
 Re: H mystery in reply to El Toro, 07-17-2005 04:09:12
Hey Hal, Shouldn't the points gap be 0.020"? I got an H with a C-169 engine with a C-175 kit in it and I set the gap according to the H specs in the IT manual. Would those specs be different for a 300 or 350?
Cheers!
Sid
El Toro
07-18-2005 06:04:57
 Re: H mystery in reply to FarmerSid, 07-18-2005 04:04:05
Hi Sid, That's .020" on a distributor setting and on mags it's .013". Hal
FarmerSid
07-19-2005 04:47:39
 Re: H mystery in reply to El Toro, 07-18-2005 06:04:57
Thanks for the correction Hal.
Cheers!
Sid
El Toro
07-19-2005 04:59:36
 Re: H mystery in reply to FarmerSid, 07-19-2005 04:47:39
No Problem, Hal
Vern
07-16-2005 21:07:33
I was having that same problem with my S/A.
Turned out that the points in the mag were oxidizing. I would clean them & it was ok until it sat for a month or so then it would do it again. I bought some points from NAPA & no more problem.
new guy at tractors
07-19-2005 17:36:48
 Re: H mystery in reply to Vern, 07-16-2005 21:07:33
thanks for your tips, i'll report back after i go thru the other side.
