706 auxiliary hydrauic control
VOLfarmall
07-17-2005 15:55:15
I have a 706 with 2 point hitch and one aux.( 2 circuit) I need one more aux.circuit. Thanks for any ideas.
Nat
07-18-2005 06:17:19
 Re: 706 auxiliary hydrauic control in reply to VOLfarmall, 07-17-2005 15:55:15
You say "1 aux," then you say "2 circuit."
If you have one auxiliary, you have ONE circuit. If you have two auxiliaries, you have TWO circuits. It can't be one of each.
So, which is it?
One auxiliary would mean one long lever to the right of the seat. Is that what you have?
If you already have two long levers there, there isn't enough room under the seat for a third auxiliary. You would need the "power beyond" block that fits on the end of the hydraulic stack under the seat, and a separate spool valve.
the tractor vet
07-17-2005 16:02:02
Like Allen said , ya can get them from a salvage yard but ya need to get the linkage to go along with it and the lines or ya can make up some hoses and make a block .
Allan in NE
07-17-2005 15:59:02
VOL,
Pick one up at a bone yard and bolt 'er up. They are additive. Just add the o-rings in between the two blocks.
Allan
Pete in Tejas
07-18-2005 13:46:42
 Re: 706 auxiliary hydrauic control in reply to Allan in NE, 07-17-2005 15:59:02
I have a 1066 with loader and it takes up both of my circuits. Can the "power beyond" be added to run a joystick off of one circuit? Sure would be nice to free up those circuits.
Pete
