Charlynn PTO Pump
RandyMcc
07-17-2005 18:34:05
I have Farmall B with a pto Charlynn hydraulic pump/reservoir. It is about the size of a bowling ball. The pump works well but leaks and the reservoir is dented. Can the pump be disassembled? Is there a rebuild kit?
Randy
gene b
07-18-2005 03:43:51
 Re: Charlynn PTO Pump in reply to RandyMcc, 07-17-2005 18:34:05
Yes parts are avail from a CHARLYNN dealer. The container will split in the middle next to the silver casting by removing the two nuts on the end. I use gasket cement on the two halves when putting together. There is a seal on the input shaft also. These are good units have used one on the B for 30pluss yrs on the loader and splitter.
RandyMcc
07-18-2005 18:22:45
 Re: Charlynn PTO Pump in reply to gene b, 07-18-2005 03:43:51
Thanks Gene. I will open it up and do the repair. Should get another 30-40 years of use.
Randy
