Order Farmall Cub Parts Online
Demo Cub ?
Snoopy
07-17-2005 18:56:15
Hi, I am hopeing someone might help me to find out if I have a "Demo Cub" or not.
The Serial number tag is gone,There is white paint all over under the 2 coats of red that I have been scrapeing off.
There are several sets of casting numbers on the clucth tube housing: (3.6.7.) 357686-R1 [.L.] 2
Any info on this would be appreciated Thank you,Donald
w gatewood
07-17-2005 20:10:12
 Re: Demo Cub ? in reply to Snoopy, 07-17-2005 18:56:15
what you are seeing may be white primer and with the serial # tag being gone it will be tought to ever prove what years it truly is , good luck
CNKS
07-18-2005 09:09:41
 Re: Demo Cub ? in reply to w gatewood, 07-17-2005 20:10:12
Depends on whether he wants to sell it as authentic. If the casting codes are mostly late S or early T, and I owned it, that would be good enough for me if I wanted to keep it. Absolutely sure it was really white, no. No one is going to get rich off of it anyway, IH painted too many of them that way.
CNKS
07-17-2005 19:47:04
I don't know if the engine serial matches the chassis serial or not. Your tractor should have late S (1949) or early T (1950) casting codes, as the white ones were produced in the 1st quarter of 1950. Some or most castings will have a number on them such as 1*8*T - Jan 8 1950, as the date the part was cast. They sometimes sat around for 2 or 3 months, thus yours could have some as early as Sept or Oct of 1949, none should be later than March 1950, though. The 3*6*7 you list could be 3*6*T, which is a good sign. The L means it was built in Louisville, as were all Cubs.
