1466 Info Sought
Adam Parsons
07-18-2005 07:53:14
I just got a phone call back from the guy who owns this 1466. I can already tell she is going to need some work before she can head to the field. The tractor is a good runner he said, clutch is good, no gear grinding, and engine runs smooth. He said the tractor dosen't have all the power she needs because the injection pump is weak on the tractor. My question is how much will it cost to rebuild the pump or get a rebuilt pump. The tractor does have a TA but from what little he has used it he says it only works when the tractor is cold. My question is how much will that cost to replace or get it working right. The tractor has a cab but the a/c dosen't work and the doors are missing. I plan to lose the cab and make her an open station. The tractor also has a loader. He is asking 5000 for the tractor but he said he is willing to talk about it. I'm just wondering what yall think of this. Thanks
Ksfarmmer
07-18-2005 18:13:40
 Re: 1466 Info Sought in reply to Adam Parsons, 07-18-2005 07:53:14
Just a WAG on my part, but I would guess that you are talking another $5K to fix everything that needs to be fixed. Think I might walk away from this one. Guess it depends on what shape the loader is in. You wouldn't have to fix the TA as long as it works in direct drive. Seems odd to say the tractor is a good runner and then say the fuel pump needs work??
Randy in NE
07-18-2005 12:03:13
Where is it located. I am looking for a tractor with some horses to pull our two row potato digger.
Adam Parsons
07-18-2005 19:43:14
 Re: 1466 Info Sought in reply to Randy in NE, 07-18-2005 12:03:13
Pump is weak not screwed up.
