544D Rocker arm shaft oiling
IH544D
07-18-2005 09:00:55
I'm in the process of putting together a tractor someone else took apart and need to know how the rocker arm shaft is supplied with oil. Is it by the small holes at the top of the shaft or is it supposed to be pressurized? Just wanted to be sure I'm not missing something. Thanks.
El Toro
07-18-2005 13:17:56
 Re: 544D Rocker arm shaft oiling in reply to IH544D, 07-18-2005 09:00:55
I think it would be under pressure through one of the cam bearings. You should get a shop manual that covers that tractor. Very helpful. Hal
