Hydraulic Lift Arm - 300 Utility
jsmith18
07-18-2005 14:40:14
I am having problems with the Hydraulic lift arm. I noticed the arm has a hole in it that looks like a pin or something fits in it. When the hydraulics would not lift or lower, I pushed a small twig into it so that it would allow me to lower or raise. What is suppose to go into this little hole to hold the arm in the correct location? Thanks.
TDK
07-18-2005 17:36:41
 Re: Hydraulic Lift Arm - 300 Utility in reply to jsmith18, 07-18-2005 14:40:14
If you're speaking of the left arm. The hole is for a pin, to make lift have down pressure. Without pin lift will float.
