650 parts
billde
07-19-2005 20:18:07
Does anyone out there have a source for sleeve&piston set for a 650D?
El Toro
07-22-2005 05:54:29
 Re: 650 parts in reply to billde, 07-19-2005 20:18:07
Doesn't the 650D have the same engine as the WD9?
The WD9 had the 350 cid engine. Check with weberstractorworks.com for sleeve kits. Cost is $1000.00 to $1100.00, they have cam bearings too
and gasket sets. Hal
Beaner
12-26-2005 13:45:52
 Re: 650 parts in reply to El Toro, 07-22-2005 05:54:29
The WD9's with a serial# OF 1801 and above have the same engine as the 650D. I just replaced the crank shaft in my SWD9 and the part# on the crank is the same. The 650D has the same engine as the SWD9. Information comferm with older IH dealership mechanich.
El Toro
07-20-2005 10:57:04
Here's a website for finding Clevite engine parts.
Hal
Http://www.engineparts.com/findastore.asp
El Toro
07-20-2005 10:40:17
Clevite should have a kit, I think I have a number
somewhere. I'll post it if I find it. Hal
McDiesel
07-19-2005 22:00:59
Hi billde, yes i think i can help you out.Howard Shuck out of Kansas should be able to help you out. The number is 800-654-5191 or 785-843-8093 If you get the Red Power magazine his ad is in there. I am restoring a 650D so i have found a few places to get parts. I am hoping to get mine running yet this summer. If you need any thing else e-mail me.
