Fan pulley flange
Rollo
07-20-2005 15:59:05
I"m trying to replace the threaded portion of my fan pulley flange (the one that tightens the fan belt)on my Farmall H. The old one is cracked so it will not keep the fan belt tight anymore. I was wondering how that whole fan pulley assembly comes apart.
Theman
07-21-2005 08:11:17
 Re: Fan pulley flange in reply to Rollo, 07-20-2005 15:59:05
Once you have removed the hub w/pulleys from the pump housing, there is a pin in the fixed half of the pulley. You may have to take a wire brush to it to find the end of the pin. It may have been painted over. Look for it near the edge of the generator pulley. The pin is short enough to come out inside the hub. Also, the hole for the pin is drilled at a bit of an angle - why, I don't know.
Rollo
07-21-2005 14:07:38
 Re: Fan pulley flange in reply to Theman, 07-21-2005 08:11:17
Thanks, I'll look a bit harder. I have been over that thing quite a bit trying to find a way it comes apart!
GordoSD
07-20-2005 21:07:10
Mine is cracked also. Where did you get a new one and how much?
Rollo
07-21-2005 14:02:32
 Re: Fan pulley flange in reply to GordoSD, 07-20-2005 21:07:10
Gordo, I bought a new one from Paynesville Tractor parts. They have a website at:>Link
I>Link think I paid around $24 for mine. Good luck!
Wayne Swenson
07-20-2005 20:25:28
Just start taking the thing apart; it is not very complicated. A parts book or copy of your local dealer"s page will help you a lot.
Send your e-mail & I can get you a blowup of the pump.
Rollo
07-21-2005 14:05:04
 Re: Fan pulley flange in reply to Wayne Swenson, 07-20-2005 20:25:28
Hi Wayne,
A shematic of the pulley assembly would be nice. Thanks! My email is: tato@brainerd.net
