400 hot hydraulic fluid
JimJP
07-21-2005 10:51:34
I have a problem and I am hoping someone may have an answer. We just bought this Farmall 400..The
Hydraulic fluid gets hot, loses power steering.
Any ideas?? Thanks for your help Jim
Mac
07-22-2005 08:15:37
 Re: 400 hot hydraulic fluid in reply to JimJP, 07-21-2005 10:51:34
If you're sure something is wrong, hear any squealing? My guess would be relief valve, cushion valve or priority (steering) divider.Have you tried to lift anything heavy yet?
Hugh MacKay
07-22-2005 01:56:01
Jim: Hot is a bit of a relative term, and I must ask, compared to what?
Farmall 300 and 400 tractor hydraulic systems ran very hot even back 50 years ago when they were new, especially on loader work or other high demand hydraulic function. If your happened to touch your arm on the lines from pump to controls, it would burn your arm. Have been there and done that one.
Here is the problem and solution. These systems have a very low oil capacity, don't remember exactly but 8 to 12 quarts. This works well if your using hitch only or a single implement cylinder in an operation like plowing. The solution is add resovoir. IH dealer added a 5 gallon resovoir to my dad's 300 when had problems on loader work. This is the history of row crop tractors in general, they built loaders for them, but they weren't engineered for it.
Don't let this deter you from what Nat has said, excessively hot may also be problem as well. If you wish to try adding resovoir, its quite simple and inexpensive to do.
Nat
07-21-2005 11:56:02
There's no one thing that could be wrong that's a "magic fix" for this problem.
By "hot" do you mean excessively hot, or just operating temperature hot???
Is this a "factory" power steering or an add-on? Is it powered by its own pump, or the tractor's main hydraulics?
Excessively hot means there's a restriction in the system causing the pump to work extra-hard when no hydraulics are being used. There's a screen on the side of the steering pedestal that may need to be cleaned. Then again, one of the valves could be stuck partially closed. Basically, you need to go through your hydraulic system component by component, work it over, to find the problem.
Operating temperature hot means something in the system is badly worn, either the pump or the motor.
Jimjp
07-21-2005 12:57:51
 Re: 400 hot hydraulic fluid in reply to Nat, 07-21-2005 11:56:02
Thanks for the reply. It is excessively hot. Factory installed (original). It is a Hydro-touch system. all powered by same pump. I am thinking there may be a restriction.
I am going through it looking for stuck valves, or anything else that may be causing the problem.
Janicholson
07-22-2005 14:30:13
 Re: 400 hot hydraulic fluid in reply to Jimjp, 07-21-2005 12:57:51
Check the ends of the control valves. There is a pin and spring plate on one end of each valve. if the pin is not centered in the correct spring notch heating will happen. I recall our's to be in the counter clockwise notch for two way action. See the manual for actual application.
Good Luck Jim Nicholson
