IH 350UD D193 ENG Kits
Rick350
07-22-2005 11:38:30
I have a IH 350 utility diesel and I"d like to overhaul engine but I can"t seem to come up with liner kit. Does anyone have any sources for this tractor?
Thanks,
Rick
El Toro
07-26-2005 08:56:53
 Re: IH 350UD D193 ENG Kits in reply to Rick350, 07-22-2005 11:38:30
I have checked every place that sells sleeve and piston kits and no one has any. Send an email to info@foleyengines.com: they handle Continental
engine parts. I sent them an email on Monday,but they never answered.
I think I would be looking for a replacement engine, there should be an engine that will fit that tractor. Most of the lettered tractors still have kits available. Hal
TDK
07-24-2005 20:25:36
Do a search on this forum. This question has been asked before and someone told of a supplier I believe in Chicago. I wrote it down, because I have a 350U Diesel myself, but it's in the shop.
hector gemme
07-22-2005 15:58:33
HI I have some use pistons and more for 350.
FarmallTom
07-22-2005 14:30:49
I believe I can get you all or nearly all of the parts you will need for the 350D engine. I am in the process of doing one myslelf. That said, I can tell you that you will almost certainly have to use used sleeves and they won't be cheap. I can't remember on the pistons themselves but everything else I was able to get from my parts supplier. Let me know if you would like me to look into it.
Thanks,
Tom J.
TNT Tractor
El Toro
07-22-2005 12:51:01
Here's a website for finding a store that sells Clevite sleeve kits. Hal
http://www.engineparts.com/findastore.asp
Illinois Boy
07-22-2005 12:11:50
Just checked their website. These people have the parts.
http://www.----- --/acatalog/sitemap.html
RickB
07-22-2005 14:07:21
 Not in reply to Illinois Boy, 07-22-2005 12:11:50
Being the cynical non-beleiver type, I checked Walts. They have no listing for either sleeve/piston/ring sets or complete overhaul kits for IH/ Farmall 350 diesel engines. I would have been surprised if they did.
Illinois Boy
07-22-2005 14:15:22
 Re: Not in reply to RickB, 07-22-2005 14:07:21
RickB,
You are correct - sorry, I did not look as close as I should have, Did not mean to mislead anyone.
I'm almost positive I have seen those parts somewhere - let me look again...
Nat
07-22-2005 11:42:20
Good luck. Parts for the diesel engines in 350s are extremely hard to come by. I don't know why nobody makes parts for those engines.
Bill in NC
07-23-2005 05:48:55
 Re: IH 350UD D193 ENG Kits in reply to Nat, 07-22-2005 11:42:20
I wonder if the old Continental cylinder liners could be re-used by: 1) honing the cylinders, 2) having a major league cylinder re-chroming and 3) using slightly larger rings.
Anybody know what steel grade was used for cylinder liners? If it is available in block stock, one could always ante up and have a machine shop mill out new liners. If the shop had automated equipment they could knock out four cylinders in fairly short time but it would be expensive.
PAULIH300
07-22-2005 15:19:55
I would imagine its because far more gasoline/LP/Distillate 350/350U engines were sold than the Continental diesel.One of the problems that occur when a manufacturer buys an engine from someone else.In this case it was a stopgap until IHs own diesel could be used.
