Super A Hydralics problem
Kyleg
07-22-2005 15:59:41
I can only use my lifts a few times before it uses up the hydralic fluid. I fill it back up and it works fine for awhile then the fluid goes down again to where it won't lift. The obvious is that it has a leak but I have looked at everything and can't find a leak anywhere?? Any ideas???
CNKS
07-22-2005 16:51:21
 Re: Super A Hydralics problem in reply to Kyleg, 07-22-2005 15:59:41
Hugh is correct -- your pump needs a seal, and possibly a speedy sleeve on the shaft if the seal has worn a groove in the shaft -- a relatively cheap fix.
Hugh MacKay
07-22-2005 16:13:19
Kyle: Check your crankcase oil pan level. If you cant see the leak, most likely it's leaking along the hydraulic pump shaft and into the crankcase.
