who has or will sell a single sleeve for a 400?
gtg155
07-23-2005 16:45:21
i have 1 bad sleeve in a 400 and dont want to buy a whole kit to fix it. does anyone sell a sleeve seperate. i have had no luck finding anyone so far. thanks
the tractor vet
07-24-2005 06:49:39
 Re: who has or will sell a single sleeve for a 400 in reply to gtg155, 07-23-2005 16:45:21
If one sleeve is cracke up and down then you had best realy check the block , you may have to bore and sleeve the block also and like they have told yo you can get just one sleeve .
gtg155
07-25-2005 17:45:31
 Re: who has or will sell a single sleeve for a 400 in reply to the tractor vet, 07-24-2005 06:49:39
no crack, piston pin retaining clip let go and ended up in the oil pan, and the piston pin took a notion to gouge the side of the sleeve.
Kelly C
07-23-2005 21:02:26
NAPA can get them only as a single.
farmallman
07-24-2005 13:53:23
 Re: who has or will sell a single sleeve for a 400 in reply to Kelly C, 07-23-2005 21:02:26
STUPID QUESTION: What does NAPA stand for? Thanks
hector gemme
07-23-2005 17:48:28
HI I should have a sleeve I check tomorrow morning .HECTOR
randy hall
07-23-2005 17:30:11
i can get you just a sleeve.
