travel speed
baler 46
07-23-2005 22:32:07
Hi I want to know what the traval speed in second and thrid grear on a h with 11-38 tires on the back but the problem is they are different sizes the other tire size is 12-38 on the back.
El Toro
07-24-2005 05:45:08
 Re: travel speed in reply to baler 46, 07-23-2005 22:32:07
Since you have unmatched tires on the rear you can calculate the road speed of each gear using a stop watch. Measure off a 100 or 200 ft level course. Start your watch when tractor is at full
speed as you enter the course, stop it when coures is completed. Write down your time for each run in 2nd and 3rd.
Here's how to calculae your speeds. Divide the 100 feet by your watch time in seconds, then divide this result by 5280, then multiply this by 3600=mph
