Farmall super a
motormouse
07-25-2005 09:59:26
how much is a super" a" worth? i think year is a 37? decent shape .Thanks--
James H in Tx
07-25-2005 19:16:28
 Re: Farmall super a in reply to motormouse, 07-25-2005 09:59:26
Look up in the photo ads for prices. Compare it to the condition and the part of the country they are i
James
scotty
07-25-2005 11:30:25
Farmall Super A was manufactured between 1948-1953.
scotty
motormouse
07-25-2005 12:08:48
 Re: Farmall super a in reply to scotty, 07-25-2005 11:30:25
what do you think value is?
Janicholson
07-25-2005 13:06:22
 Re: Farmall super a in reply to motormouse, 07-25-2005 12:08:48
If it was show ready new tires all around mechanically perfect, and had no attachments it might be as much as $2300. it might go down to the scrap price for iron on the low end. Probably in the area of $1000. It also depends on two other factors. What are the prices in your area of the country, and do you (and your other special people in life)like it a lot.
If you like it buy it. Do not expect income from a resell.
Jim Nicholson
motormouse
07-26-2005 05:06:42
 Re: Farmall super a in reply to Janicholson, 07-25-2005 13:06:22
model-faa. 34296. 1540. Those are the numbers i took off tractor. can anyone help with some info? thanks i'm new to all of this so please bear with me.
Harold H
07-26-2005 05:40:52
 Re: Farmall super a in reply to motormouse, 07-26-2005 05:06:42
You apparantly have a 1940 Farmall A, not a Super A.
Harold H
motormouse
07-26-2005 13:20:08
 Re: Farmall super a in reply to Harold H, 07-26-2005 05:40:52
The tractor has front and rear hydraulics, lights on front, red and white light on back(changes) starts and runs excellent.paint is good , may have been sprayed?wide front end,snow plow,rear tires are good and fronts are a bit dry.
Harold H
07-26-2005 13:40:09
 Re: Farmall super a in reply to motormouse, 07-26-2005 13:20:08
I was going by the serial number you posted, 34296. A serial numbers run from 6744 to 41499 for 1940. Super A serial numbers run from 336880 to 355547 for 1953, which have one more digit than your number. Double check your number again.
Harold H
motormouse
07-26-2005 15:33:16
 Re: Farmall super a in reply to Harold H, 07-26-2005 13:40:09
checked again #342967, also has wheel weights on the rear.
Harold H
07-26-2005 16:59:03
 Re: Farmall super a in reply to motormouse, 07-26-2005 15:33:16
It is a 1953 Farmall Super A.
Harold H
motormouse
07-26-2005 17:07:38
 Re: Farmall super a in reply to Harold H, 07-26-2005 16:59:03
What do you think it's worth? Thanks for the help!
