TA?
Illinois Boy
07-25-2005 11:26:35
I beleive my 350 does have a TA, even though the clutch linkage is gone and a hole on the trans has been sealed. (Thought I might break 'er down this winter and get the TA working)
Can anyone confirm - if a serial number is followed by a designator letter, the letter means one of various options are on the tractor.
My 350 has an "S" following the serial number, which I believe means Independent PTO with TA.
Thanks in advance...
Pestering you again from Illinois!
Aces
07-25-2005 15:19:02
 Re: TA? in reply to Illinois Boy, 07-25-2005 11:26:35
Illinois Boy If it has a TA with the linkage removed the tractor will shaft hard because both main and TA clutch must reliese at the same time so I would say it was taken out and a shaft put in as if never had TA.
Mr Bill No. Mn.
07-25-2005 13:09:41
Hi people-Have been rfeading this forum along with the grey and red. Curious- what does TA stand for and what is it? Don`t own a red tractor but someday will. Used to drive one of the neighbors when I was a youngster. Thanks for any replies.-Bill
Illinois Boy
07-25-2005 13:25:37
 Re: TA? in reply to Mr Bill No. Mn., 07-25-2005 13:09:41
Bill,
It stands for Torque Amplifier. I believe some other manufacturers have a similar way of accomplishing this and give it different names. Basically, its a way to downshift to a lower gear ratio, on the fly, without stepping on the clutch, should the operator hit a rough spot with a plow (i.e. clay soil), baler (i.e. heavy spot in windrow), etc. It's an IH thing wher you can lower the tractor to get through a rough spot, and then shift back up to the original speed - all done in the same gear without stopping the forward motion of the tractor.
Mr Bill No. Mn.
07-25-2005 16:09:39
 Re: TA? in reply to Illinois Boy, 07-25-2005 13:25:37
thanks for the reply- now I know what you fellas are talking about. sounds like they were somewhat common on those tractors.=Bill
Red Dave
07-25-2005 11:45:42
The info I have says "S" as a suffix means T/A with provisions for IPTO too. So it seems like it did have T/A when it came out of the factory.
It sounds like somebody may have removed it though. Hard to tell what may have been done over the past 50 years.
Illinois Boy
07-25-2005 11:52:40
 Re: TA? in reply to Red Dave, 07-25-2005 11:45:42
Thanks RD...
Probably quite working and was "abandoned".
Looks Like I'll have a "project" this winter...
