F-20 rear wheel seal
Paul G. in Mn
07-25-2005 12:47:57
I am restoreing a 1939 F-20 and one of my rear wheel seals are leaking. I have not dug into this yet but am wonding what kind of a job it is to fix this and also what type of seal it is? Any idea were I might find a replacement seal? Thanks Paul
JohnG(TX)
07-25-2005 14:19:30
 Re: F-20 rear wheel seal in reply to Paul G. in Mn, 07-25-2005 12:47:57
Paul,
The seals can be gotton from Rice in PA. The job of replacement is not too bad. Remove the cap on the inside of the bull gear housing and loosen the nuts in there. Jack up that side and remove the wheel. The axle pin will pull out and the seal in on a carrier mounted on the axle pin. I can send photos of the action if you need.
JG
Paul G. in Mn
07-25-2005 14:25:42
 Re: F-20 rear wheel seal in reply to JohnG(TX), 07-25-2005 14:19:30
Thanks, sounds pretty easy. Do you have contact information for Rice in Pa?
JohnG(TX)
07-25-2005 14:32:28
 Re: F-20 rear wheel seal in reply to Paul G. in Mn, 07-25-2005 14:25:42
I don't have it with me right now, but do a search for "Gordon Rice" and I'm sure you will find his info. It get posted several times a month.
JG
