Need help retiming my M?
Bobg
07-25-2005 20:05:06
I did a stupid one tonight. I was tinkering with my M, I was checking the points in the mag. Checked the gap to see what it was set at. Put the cover back on and decided to check the grease under the small cover that house the two small gears. I pulled it apart and as soon as I did I knew I was in trouble.
Can someone tell me how to retime it and what kind of grease to put on the gears? I really need to get a repair manual.
Any help appreciated.
Bobg
El Toro
07-26-2005 05:55:10
 Re: Need help retiming my M? in reply to Bobg, 07-25-2005 20:05:06
Try binderbooks .com for your mag manual. The manual GSS-5035 cover's the IH mags for $17.95.
Hal
Bob
07-25-2005 21:12:25
Link
Bobg
07-26-2005 14:28:06
 Re: Need help retiming my M? in reply to Bob, 07-25-2005 21:12:25
Thanks, Bob.
I tried setting the gears by putting #1 at TDC and then lining up the rotor at #1. Last night I decided to quit messing with it since I knew there was an easier way. I was off two cogs on the small gear. It started right up after I got the two gears timed.
Thanks again.
Bobg
