Sleeve tool for 706
Kelly C
07-25-2005 21:40:05
Well I decided to replace my old sleeves and pistons on my 706 my self. $460 is cheap enough I guess. Any one got a line on where to get a disk to pull the sleeves. I have a puller but only have the disks for a 300,350, 400 and a H
MN Scott
07-26-2005 18:33:25
 Re: Sleeve tool for 706 in reply to Kelly C, 07-25-2005 21:40:05
In the long run I think you will be glad you rebuilt the engine you have. I have a feeling that those combine engines would cost you more in the end as you would end up rebuilding them to. Just make sure you don't cut corners on the valve job. A good job is critical to these gassers. As for the puller disk just have your local machine shop make one if you can't borrow one. Make sure to keep us posted and don't forget pictures. Good Luck!
CEB
07-26-2005 10:36:14
Kelly,
Just have your local machine shop make one for your puller. Bring your puller in and one of the new sleeves and they will take it from there.
GordoSD
07-26-2005 05:50:39
I went to my local IH dealer shop. The mechs there had a box with about 25 puller discs. I was able to borrow one for 1/2 day, which is all I needed. Cost me a 12 pack.
Gordo
El Toro
07-26-2005 03:41:31
Try E&K Ag Products in Gainesville, MO; their number is 417-679-3530. Hal
