Abrasion Sleeves on Hydraulic Hoses
Dave in CT
07-26-2005 07:58:15
Even though the outer layer of rubber on a good hydraulic hose is designed to take abrasion, I'm investigating getting further protection from abrasion and UV by using those fabric sleeves I see on modern equipment. I'd like to hear from those folks that use the sleeves, how are they performing and where is a good place to pick some sleeving up? Any feedback on this issue is welcome.
Mike ISW
07-26-2005 14:02:48
 Re: Abrasion Sleeves on Hydraulic Hoses in reply to Dave in CT, 07-26-2005 07:58:15
We use them at work on most hoses and they work/protect well. Gates hose distributers should have it for you.
Dick in LA
07-26-2005 13:03:08
Those sleeves work great and have eliminated hose wear and damage for us.
Dave in CT
07-26-2005 15:59:56
 Re: Abrasion Sleeves on Hydraulic Hoses in reply to Dick in LA, 07-26-2005 13:03:08
Good news. Where do you get them? How do you determine the size relative to the hose size? How do you finish the ends of the sleeves - just cauterize the cut nylon? Thanks for the input.
RustyFarmall
07-26-2005 10:10:54
This is also a good use for those old garden hoses you have been meaning to get rid of, Cut to the length you need, slit it open, and wrap around the hydraulic hose. Secure it with zip ties.
Hermit
07-26-2005 08:42:28
Wire loom might also work.
El Toro
07-26-2005 08:40:12
Alemite and Weatherhead hose distributors should have them too. Hal
Bob
07-26-2005 08:07:06
An industrial hydraulics distributor that sells Aeroquip should have them.
