sheered bolt on super a
PaulH
07-26-2005 12:42:00
Recently i sheered off the head of a bolt while removing the right front set of cultivators of a super a. Can i bore this out? Does anyone have any suggestions.
many thanks
Paul
hugh MacKay
07-26-2005 13:14:42
 Re: sheered bolt on super a in reply to PaulH, 07-26-2005 12:42:00
Paul: I'd be kind of curious as to which bolt. If it is one of the four that hold lift frames in place, they can get threads damaged on inner end thus it makes them difficult to remove.
El Toro
07-26-2005 13:04:59
If enough of the broken bolt is protruding I would
weld a nut to it and then see if the broken bolt
can be backed out. Apply a little anti-seize to the threads of the new bolt. The heat will help to loosen the bolt. Hal
