Super H Fuel leak
Al in VA
07-26-2005 15:20:32
I rebuilt my carb and now it leaks around the fuel line connection to the fuel screen fitting. Did I lose something or did I just take it off one to many times. I appreciate any suggestions.
El Toro
07-26-2005 17:06:14
 Re: Super H Fuel leak in reply to Al in VA, 07-26-2005 15:20:32
Wrap some teflon tape around the backside of the
ferrule. Get the tape in the pink spool, it's for oil, gasoline and natural gas. I got mine from Home Depot. Hal
Al in VA
07-26-2005 19:37:42
 Re: Super H Fuel leak in reply to El Toro, 07-26-2005 17:06:14
Thanks
Al
El Toro
07-27-2005 03:53:29
 Re: Super H Fuel leak in reply to Al in VA, 07-26-2005 19:37:42
You could also try using a pipe dope called Gasoila. Just coat the tube fitting threads on the carburetor, then install the compression nut.
Website for it is: federalprocess.com Hal
Dave_Id
07-26-2005 15:27:27
Did you have a compression fitting, and replace with a tapered pipe fitting? If it's a compression fitting, maybe it's been compressed one too many times, and no longer seals.
Al in VA
07-26-2005 15:35:35
 Re: Super H Fuel leak in reply to Dave_Id, 07-26-2005 15:27:27
It is a compression fitting. It looks ok but I think you are probably correct I took ir off one to many times. Thanks, Al
