Order Farmall Cub Parts Online
looking for info for farmall cub farming
4h
07-27-2005 07:31:21
the county farm by me has garden 200ft x 800ft and the farmer wanted to get a cub with a plow to plow it. the garden has a eltric fenc that can not be removed would a cub be able to work in a area like that
CNKS
07-27-2005 08:24:30
 Re: looking for info for farmall cub farming in reply to 4h, 07-27-2005 07:31:21
I used to do agronomic research on small plots, more like 80 by 200. Although they weren't fenced, I could turn a JD 4020 or larger (pulling a 15 ft wide undercutter (sweep plow) around in a 20 foot alley between plots without using reverse. A Cub should easily do that 10 feet from the fence, easier if he drives to the fence, reverses, then turns around and aligns himself. In other words, a Cub is fine.
El Toro
07-27-2005 07:58:54
I think a Cub would work fine in that area. That area is is about 3.7 acres and he could use a larger tractor if he could get the tractor inside that fence. Hal
