Zenith carb question
Phillip Womble
07-27-2005 14:23:47
Recently bought a Cub with Zenith carb. The float was obviously not working properly as gasoline would constantly run out the bottom of carb. Took carb apart and cleaned needle valve so that it should now work properly. My question is about a very small coil spring that mounts around the pin that holds the float in place. This spring came out when I removed the float pin and I cannot figure out the correct way to put it back in. To complicate matters, this spring is not shown in parts catalog TC-37F.
Can anyone let me know what this spring is for, and how to properly reassemble it in my carb?
THANKS!! P.Womble
scotty
07-28-2005 06:14:37
 Re: Zenith carb question in reply to Phillip Womble, 07-27-2005 14:23:47
Phil, If memory serves me, one end of that spring goes around the end of the needle valve and the other slides onto the back side of the float on that flattened section. I hope this is clear as I do know what you are refering to.
scotty
