2500A backhoe, similar tractor?fianl drive planeta
pats tractor
07-27-2005 14:58:00
hello you IH gurus, I have a IH 2500A backhoe loader tractor, Is there a tractor that is the same frame as this backhoe?, I have a broken planetary gear on the left side final drive. I broke the ring gear as well, so I am in need of the 3 planetary gears, the ring gear that goes around the housing, and the shaft that connects the final drive to the transmission end,,,thansk for any help, I have a few numbers if it would help, the 3 pinions are 66128C3,,the shaft is 404343R1,,and the ring gear is 535317R1,,,
also if there is nayone who has these parts or the whole final drive unit available let me know,,I also cracked the housing, thansk pat
JB2
07-27-2005 17:06:55
 Re: 2500A backhoe, similar tractor?fianl drive pla in reply to pats tractor, 07-27-2005 14:58:00
Hi Pat, according to an OEM parts catalogue that I have a 2500A is same as 574,674,584 ag tractors.
Does it have a 4 cyl D239 Diesel engine or a 3 cylinder D179 Diesel engine? The D179 goes with 454,484,485,495 ag tractors. The D239 goes with 574,674,684,695 ag tractors. All these tractors share the same parts from the clutch housing back except for different gear ratios in transmission.
Good luck finding parts.
JB2
pat,maplehillfrm
07-27-2005 20:18:23
 Re: 2500A backhoe, similar tractor?fianl drive pla in reply to JB2, 07-27-2005 17:06:55
thanks for the response, I have the 4 cyl diesel in her, I am hoping I can find parts, seems from a few discussions it is going to be fun,, funny thing is I have a 454 with a gas engine,and a loader, a few weeks ago the spindle went on her and I was going to switch the loader onto a 544 I have,, I fixed the spindle and away we went,,,, well if the final drive is the same as the 2500a as the 454 , I may have a lot of switching to do, I looked at the axles and they looked the same this afternoon on the 454 , but I was thinking it was smaller in diameter?,then I would have extra parts for other break downs,,man my mind keeps going and going,,, but I am going to look closer in the morning, thanks I really appreciate it,pat
pdw
09-06-2005 13:52:38
 Re: 2500A backhoe, similar tractor?fianl drive pla in reply to pat,maplehillfrm, 07-27-2005 20:18:23
I have a 2500a with the d179 3 cyl diesel that is shot. If you wind up parting your 454, I might be interested in the engine if its running.
Paul Wallace
scooterbill1@yahoo.com
