966 TA
Fredd
07-28-2005 07:32:32
I have a 966 tractor. The torque works great when the handle is forward. When the tractor is pulling hard and the torque is pulled back nothing, you just stop. If you push the clutch in and then pull it back like changing gears then it will work. If you have ti pulled back and are turning har and using the brake to help the front end around a little then sometimes it will stop. What is wrong any help appreciated. Thanks
