implements for my year range?
Darren In Pesot
07-28-2005 12:12:38
Hey all,
Is there anywhere you have run across that lists the implements available from IH for the years around my tractor (1970). I would think there would be a sales brochure available somewhere that would list the line or something, but I haven't found one. Just curious!
My wife thinks there is something wrong with me for wanting to get a bunch of correct implements, but the search is fun, and my goal is to turn my Farmall 656 into a swiss army knife of tractors!
Thanks,
Darren
Hugh MacKay
07-30-2005 01:36:19
 Re: implements for my year range? in reply to Darren In Pesotum, 07-28-2005 12:12:38
Darren: The opinion given by CNKS is about right, by then every manufacturer was following that 3 point standard. Big item to watch for along these lines is Catergory. Your 656 is Cat II. I had a 656 back in those days and found some Cat I equipment, even though you could install bushings, just didn't have the right measurments for the larger hitch.
To give you some ideas, I have a 1968 buyers guide in front of me. By then 656 had been on the market 3 years. In field cultivators the Vibra Shank 45 was in, available in trailer, 3 point or fast hitch. I pulled a 12' trailer with my 656 or 560. On plows the semi-mount was in models 500 or 700, 656 will handle 3 to 5 - 16" bottoms depending on your soil. I pulled 5x16 in sandy loam. Those plows had much the same bottom, the 700 just had a larger frame giving more clearence for trash like corn stalks to flow. On front mount cultivators the 78 model number was current.
Disk harrows from IH included 350, 370, 470 those came in sizes for 656, althought the smallest 470 was 12' and I expect that would make a 656 grunt. I pulled 10' of disk with my 656. Newer disks in the late 1960s were starting to get some weight, thus would cut much deeper than we were used to.
Corn planter of the day was model 56, but the 400 air planter came fast on it's heels. No.10 grain drill was in, I had a 12' 24 run with 6" spacing.
I'm not going to comment on haying eq. just list what IH was selling. 816 mower conditioner, 100 series balanced head mowers, 14 and 16 rakes. Balers were 27, 37, 47 and 57. Loaders were the 2000 or 2001.
Darren In Pesotum
07-30-2005 18:24:47
 Re: implements for my year range? in reply to Hugh MacKay, 07-30-2005 01:36:19
Hugh,
Thanks for the detailed information. That's just what I was looking for. I already have a 2000 loader for it, and I also picked up an IH rack wagon that is about 20 years earlier, but that's OK. The model #s you mentioned will give me some direction on what to look in to.
Thanks for both replies guys!
Darren
CNKS
07-28-2005 12:36:40
I imagine there is sales info somewhere, IH did put out an annual catalog, likely hard to come by. By 1970, everyone had converted to 3 point, and many manufacturers made implements suitable for your tractor. Same with trailing implements. That is, the "correct" implements in the 60's and 70's meant little. Exceptions would be things like front mounted cultivators, which would have been manufacturer specific.
