snowblower?
brainerd dave
07-28-2005 12:23:35
Yep, I know it's 90 degrees out there, so what better time to start thinking of winter? Anyone ever rig up a snowblower to an H pto? It sounds like a fun project to work on during my week off. If you can clear snow sitting down, life doesn't get any better.
Minnesota Marv
07-29-2005 01:27:02
 Re: snowblower? in reply to brainerd dave, 07-28-2005 12:23:35
I've got a 7 foot blower on my M. It's V shaped with a short auger screw and impeller on the PTO shaft. The only drawback is that you have to drive through the snow first, but I figure if the snow is too deep to drive through, the M won't have the HP to blow it anyway. If the M can handle a 7 foot, the H should be able to handle a 5 or 6 foot blower. I have a pic posted on this site in the Farmall Photo Gallery. If you search on 1947 Farmall M, you will find it.
Marv Gustafson
brainerd dave
07-29-2005 05:13:53
 Re: snowblower? in reply to Minnesota Marv, 07-29-2005 01:27:02
Thanks Marv. Nice rig.
If I can't find a decent blower to try, I'll put the loader back on for the winter.
K-Mo
07-28-2005 20:31:47
You may need to consider ground speed. For efficient blower operation, you will need to run the PTO at full throttle. If your blower is rear mounted and driven in reverse, your ground speed may be too fast handle the volume of snow.
K-Mo
Dave_Id
07-28-2005 13:06:46
I think the humidity got to ya...
Dave_Id
07-28-2005 14:19:14
 Re: snowblower? in reply to Dave_Id, 07-28-2005 13:06:46
Seriously though, I have a Saginaw 3 point on my Super C, and it runs the snow blower nicely. An H should work just as fine.
