1949 H Seat, Canvis, or Vinal?
KW650
07-28-2005 15:43:55
Shaould a 49 H have the canvis seat or the vinal seat? I just want to make sure I get the right one. I cant seem to find any thing that tells me witch would be right. Thanks for any help!
TDK
07-28-2005 20:23:02
 Re: 1949 H Seat, Canvis, or Vinal? in reply to KW650, 07-28-2005 15:43:55
The canvas is correct. It is harder to keep clean. I usually keep a plastic trash bag on mine when not at a show. The vinyl is easily cleaned, but the first time you sit on it out in scorching sun you'll know why IH used canvas. The best advice is - it's your tractor, used the type you like the best.
Allan in NE
07-28-2005 22:59:09
 Re: 1949 H Seat, Canvis, or Vinal? in reply to TDK, 07-28-2005 20:23:02
TDK,
They used canvas because vinyl wasn't even dreamed up yet when these old letter series tractors were built.
Allan
TDK
07-29-2005 11:10:51
 Re: 1949 H Seat, Canvis, or Vinal? in reply to Allan in NE, 07-28-2005 22:59:09
You're probably right Allen. But I was thinking that they were still using the same material up to '58, for the same reason I stated.
John M
07-28-2005 17:21:33
The first trime you sit down on a wet seat youll wish you had the vinyl.
CNKS
07-28-2005 16:52:53
Allan is correct -- I have both, I don't like the canvas because it gets dirty easier and is next to impossible to clean. It also won't last long if you use it a lot. The canvas on the old Farmalls was the 1st thing to go, I doubt if the new seats are any better.
KW650
07-28-2005 17:14:39
 Re: 1949 H Seat, Canvis, or Vinal? in reply to CNKS, 07-28-2005 16:52:53
Hay thanks for the info. This will be my first H. most of my projects have been green. But when I found this jem off of a little tobaco farm. I just could not pass it up. Tight stearing, perfict tin (minus two little dings in the grill), perfict fenders, never repainted, like new light bar tool box, pTO guard, and runs great. All for only $900. Shure beats the green prices!!
CNKS
07-28-2005 18:29:53
 Re: 1949 H Seat, Canvis, or Vinal? in reply to KW650, 07-28-2005 17:14:39
Sounds like you got a bargain -- The two places I will deviate from OEM are seats and paint, and perhaps a 3-point hitch.
Allan in NE
07-28-2005 16:39:13
Canvas
Allan
KevinDM
07-29-2005 07:55:45
 Re: 1949 H Seat, Canvis, or Vinal? in reply to Allan in NE, 07-28-2005 16:39:13
Oxi-clean (couple scoops) and a little dish soap and water (hot), scrub thoroughly, rinse, repeat if needed. Let dry COMPLETLY. Made our canvas seat look like new again. Now if I can only keep the shop cat off it when we're not looking!
KevinDM
07-29-2005 07:54:44
