Order Farmall Cub Parts Online
International cub flooded
Chrisfromsolitude
07-30-2005 14:48:41
I just bought a 1975? International cub and I put new coil, points, condensor, and plugs in it. It runs but acts like it is flooding itself out. If you shut the gas off and let the carb drain it will run good on what is left in the carb. Can anybody tell me where to set the float and the needle? I have a book for my 48 cub but it's different than this tractor. Thanks.
Bigdog
07-30-2005 19:03:12
 Re: International cub flooded in reply to Chrisfromsolitude, 07-30-2005 14:48:41
If it's the Zenith carb the float is 1 5/32 with a 3/16" drop.
Specs for all the carbs can be found here:
http://www.cleancomputes.com/Cub/Maintenance%20Tips%20and%20Techniques/Lurker%20Carl's%20Cub%20Carb%20Fixes/Fuel%20System.htm
