IH Farmall 656 Hi Clear Diesel W.F.
Hanz Nussbaum
07-31-2005 15:32:35
I have a chance to buy this tractor,mechanically good shape,needs some cosmetic work,and I think it has the wrong front axle on it.Any information on specs on this tractor would be appreciated,especially about the front end.It has 15.5 x 38 in rears on it
Harold H
07-31-2005 16:14:12
 Re: IH Farmall 656 Hi Clear Diesel W.F. in reply to Hanz Nussbaum, 07-31-2005 15:32:35
What makes you think it is the wrong front axle? All Farmall 656 Hi Clear tractors had wide front axle.
Harold H
Hanz Nussbaum
07-31-2005 19:14:57
 Re: IH Farmall 656 Hi Clear Diesel W.F. in reply to Harold H, 07-31-2005 16:14:12
What makes me think it is the wrong axle is that it is not sitting level at all .The front of the tractor is quite a bit lower than the back,Not sure if it is the wrong spindles,wrong rims/tires.??? Thanks for the reply
El Toro
08-01-2005 03:58:53
 Re: IH Farmall 656 Hi Clear Diesel W.F. in reply to Hanz Nussbaum, 07-31-2005 19:14:57
What size are on the front? Hal
