350 starter system
Jimboy
07-31-2005 20:00:22
This "58 has been converted to 12 volt (still pos ground)
but I sometimes have to hit the button 20 times to get it engaged and the terminal on the solenoid starts glowing red! Could this be a problem with bad teeth on the flywheel? A bad spur gear on the starter? The guy I recently got it from said he replaced the solenoid pretty often. Doesn"t really sound like a solution. Anyone with a better one? Thanks...
RustyFarmall
08-01-2005 04:27:47
 Re: 350 starter system in reply to Jimboy, 07-31-2005 20:00:22
Any time an electrical terminal gets hot and glows red there is a very poor electrical connection. The heat is caused by electrical resistance, the resistance is caused by rust, corrosion, or just plain being loose. Remove the connection and clean it good, might even need to use some emery cloth to make things nice and bright. The bad part here is that things may have become hot enough that permanent damage has been done, in which case you will need to replace your solenoid and possibly install a new terminal on the end of the cable, or replace the cable.
old
07-31-2005 21:00:48
Sounds like it could be a bad battery cable/to small of a cable or both.
