Super M Water Temp Gage Fitting
gusc
07-31-2005 21:00:43
My SM block has a short nipple with a female T screwed on to it. In the front of the T is the water temp bulb, in the rear is a pipe plug.
I can't figure out any reason for that setup, why isn't the water temp just screwed directly into the block?
DAR
07-31-2005 22:04:32
 Re: Super M Water Temp Gage Fitting in reply to gusc, 07-31-2005 21:00:43
MY super m had that too. probably what it is is the pre. owner had a block heater on the engine and put a t in so he could have the heater hose go into the head and still have a temp sensor.
gusc
08-03-2005 21:50:07
 Re: Super M Water Temp Gage Fitting in reply to DAR, 07-31-2005 22:04:32
DAR,
Makes sense, never thought of a block heater since I live in a warm climate.
I forgot to mention that it was originally LP and converted to gas just before I got it. Don't know if that makes any difference.
Thanks.
