Re: c three point
CNKS
08-01-2005 06:02:24
Dave's source is ok. Worksaver hitches work off the front rockshaft, Saginaw's have their own cylinder, greater lifting capacity plus no rod running by your feet. Not a whole lot of price difference wxcept that Saginaw does require a block between the hyd reservoir, and the tubes and a spool valve that mounts on the light bar, unless you have the factory remote. You have to buy your own hoses, added together, that is more expense, but well worth it. Saginaw is very heavy construction, almost to the point of overkill. I have one on a Super H, one on a C -- both excellent products. Not as good as modern factory 3-points, but as good as you can get for letter series tractors.
Dave in CT
08-01-2005 06:16:27
 Re: c three point in reply to CNKS, 08-01-2005 06:02:24
I would've recommended Saginaw first as well but they don't mention one for a C on their web site. I guess the one you already have on your C would refute that. Yeah, go with Saginaw.
CNKS
08-01-2005 10:51:48
 Re: c three point in reply to Dave in CT, 08-01-2005 06:16:27
Since there were so many more H/M's built than the C, I imagine he sells many more for those tractors. Acually, a Saginaw that fits an H will also fit a C, as the axle brackets are the same width apart, and the bolt spacing is the same. The C does not need the added strength, though.
