Hyd. oil too hot too quick
fixitforfree
08-01-2005 06:19:18
My 364 diesel with pwr. strg. has the dual hyd pump setup and I notice after running the tractor only 20-30 minutes the hyd oil gets real hot and the hydraulics get weak. What could cause this? I know there is a "weep hole" on my strg cyl that leaks pretty bad so I assume I need a rebuild on that cyl but can other restrictions in the valving under the seat be a big cause of this premature oil heating and weakness?
