Order Farmall Cub Parts Online
cub cadet 149 48 deck mowing problems
mbilak
08-01-2005 08:09:37
Is ther any one out there that can help me with this problem. I have a Cub Cadet 149 with a 48" deck that I have put new blades on. The problem is, it still misses 2 strips of grass. Between the 2 outer blades from the center blade. When I had the deck off to replace the blades I checked the clearence between the blades and it was about 1/16". Any help? thanks Mark
Red Dave
08-01-2005 10:01:02
 Re: cub cadet 149 48 deck mowing problems in reply to mbilak, 08-01-2005 08:09:37
My Cub Cadet with a 42" deck has about the same clearance between the center and outside blades. It doesn't skip.
I'm skeptical that you would even notice a skipper made by a 1/16 inch gap.
Are your blades sharp?
mbilak
08-01-2005 11:21:53
 Re: cub cadet 149 48 deck mowing problems in reply to Red Dave, 08-01-2005 10:01:02
I thought about what you said about overlaping and yesthey do overlap being the center blade longer then the 2 outer ones and that center blade foward, so yes they do over lap. The blades are brand new and I just put them on on Sat. The deck in in good shape and the next thing I'm going to try is sand blasting and paint t5he underside. This mower has done this with the old blades and new ones thanks
El Toro
08-01-2005 12:07:56
 Re: cub cadet 149 48 deck mowing problems in reply to mbilak, 08-01-2005 11:21:53
Are you sure you have the cutting edge of the blade rotating in the right direction? Hal
MBILAK
08-01-2005 12:40:59
 Re: cub cadet 149 48 deck mowing problems in reply to El Toro, 08-01-2005 12:07:56
Yes the blades are correctly the new blades even say bottom on them.
mbilak
08-02-2005 17:03:27
 Re: cub cadet 149 48 deck mowing problems in reply to MBILAK, 08-01-2005 12:40:59
Well after a little research and since I"m new to this tractor, I found the ID tag on the rear
2050047U43851. And the mower ID tag 482U1113.
Can any one tell me about this tractor?
El Toro
08-01-2005 14:15:39
My 42-inch rear discharge mower was made by Gilson and it never leaves a strip and the blades do not overlap. I went out and looked it over to make sure. I have a set of spare blades too and they're all the same length. I've had the mower for 30 years. Hal
Nat
08-01-2005 08:21:31
You've got the wrong blades. They need to overlap, or you'll leave strips.
