U-drawbar on Super C (PHOTO)
SGT K
08-01-2005 08:42:39
third party image
Has anyone seen a U-shaped drawbar like this on a Super C before? I first thought it came off of an H, but it is about 2 1/2 inches narrower. It fits right on the axle housing and if someone cut one down off af an H, they sure did a good job because I can't see the weld.
Just curious,
Paul
bnowen
08-01-2005 20:16:19
 Re: U-drawbar on Super C (PHOTO) in reply to SGT K, 08-01-2005 08:42:39
I have a 49 model with the bar that is on the center of yours but not the one attached to the axles. It has been in my family since new and has never had a bar like that. I thoguth I"d add it for what its worth.
CNKS
08-01-2005 18:06:28
You sure it's narrower? I bought a C with that drawbar on it, the previous owner had a sickle mower bolted on it. I put that same drawbar on my 460 Hi Utility (same rear end as the row crop), to pull it out of my building when I had the fast hitch off. It fits perfectly. Thus the U part will bolt on everything from the C to the 460.
KIP in MX
08-01-2005 09:03:43
Looks just like the drawbar we had on our SC.
SGT K
08-01-2005 11:07:56
 Re: U-drawbar on Super C (PHOTO) in reply to KIP in MX, 08-01-2005 09:03:43
I recognize the drawbar as the same, but I had never seen one with the U-bar. I didn't realize they made them like that. I learn something every day (wich isn't too hard, since I'm not too smart to start with) ;)
KIP in MX
08-01-2005 12:51:50
 Re: U-drawbar on Super C (PHOTO) in reply to SGT K, 08-01-2005 11:07:56
Ours had the same set up you have on yours. We used the U bar to mount a JD #5 mower.
