W9 PTO swap
Chad Franke
08-01-2005 10:28:00
Well, I got a mower to pull with my W9, problem is that I don"t have a PTO on the W9 that runs...I"m going to steal the PTO out of a parts tractor, but wanted to ask (since I don"t have a shop manual yet) if it is more involved than it looks. Is it an unbolt-rebolt afair? Thanks for any help.
Roger in Iowa
08-01-2005 18:36:22
 Re: W9 PTO swap in reply to Chad Franke, 08-01-2005 10:28:00
Helped my dad install pto about 55 years ago in a WR9. Just put the front wheels down in a grader ditch or steep hill to keep the oil from running out of the rear when you remove the plate. Pretty straight forward. Might slip a pipe over the implement splines to balance the shaft when installing. Helps raise the front end to line it up with splines in trans.
Have fun!
Roger in Iowa
