560 hydraulic pump
Robhkent
08-02-2005 10:45:48
Is there a way to tell which pump I would have in my 560 D? It has a fast hitch, has three hydraulic outlets including the fh.
Rob
Tim Shaw
08-02-2005 19:44:04
 Re: 560 hydraulic pump in reply to Robhkent, 08-02-2005 10:45:48
On the serial # plate, Y is 12 gpm hyd. pump and Z is 17 gpm hyd. pump.
robhkent
08-03-2005 08:13:22
 Re: 560 hydraulic pump in reply to Tim Shaw, 08-02-2005 19:44:04
Tim:
Thanks for being the bearer of bad news.... my serail # ends in a Y. Therefor Imhave a 12gpm pump. This is not a real problem yet..... I just had hopes for the bigger pump.
Thanks
Rob
Robhkent
08-02-2005 19:26:57
Thanks guys, will check those avenues. I did look in the archive before I asked the question, but got so many responses. I need to be more specific in my search.
Tahnks
Rob
El Toro
08-02-2005 18:28:42
It may be a Cessna pump. SteelWheelRanch would probably know. Call them at 785-548-7437. Hal
Colorado Curt
08-02-2005 15:37:21
There should be a stamped letter on the serial number tag that will indicate the pump output. I cna't remember what it is, I think it is S or Y. Search the archives, I know it has been talked about. Do you have power steering? There may be a piggy-back pump for the powersteering.
