Order Farmall Cub Parts Online
Cub clutch
wdtom
08-02-2005 18:32:11
I tried to adjust the free play in the clutch pedal of out cub as it seemed excesive. When I did and then drpressed the pedal I could hear the linkage hitting something in the bellhousing. Am I right that the throwout bearing is worn out and allowing the linkage to go too far and strike the clutch cover or some such? These are a carbon bearing? How does that work? What are you greasing when you grease it. I haven't had one apart, trying to learn before I take it apart. Thanks.
Tom
wdtom
08-04-2005 18:36:44
 Re: Cub clutch in reply to wdtom, 08-02-2005 18:32:11
Thanks for the ideas, I will follow up on them and see what I can do with it. Tom
gene (Missouri)
08-03-2005 10:46:43
As George states you can adjust the fingers on the pressure plate. While you are under the Cub take a look at the front face of the throwout bearing. If you see much of a groove in the throwout bearing - replace it.
Just over $50.00 for the throwout bearing.
Gene
George Willer
08-03-2005 07:08:30
You can probably fix it without splitting. The other adjustment you should make first is the height of the clutch fingers. Adjust them so they are all 1 1/4" above the plate... a difficult job, but it can be done. With my big hands, I have to use a gauge made with a drywall screw projecting 1 1/4" from the side of a small stick near the end.
A lot of guys have had trouble with aftermarket TOBs, mostly, I think, because they don't come pre-lubed and guys neglect to lube them. If you use one, grease it till grease comes out the little hole opposiite the zerk and then put a thin film on the contact surface. They will work out just fine.
George Willer
old
08-02-2005 19:25:56
Did one of those last summer, yep its a carbon one. They where not the best things but they did work. My guess is that it is shot. Not really to bad to split and put a new one in if you have a way to lift the engien
gene (Missouri)
08-02-2005 19:23:41
Sounds like the throwout bearing is worn out. They are carbon bearings and work and look like most throwout bearings. There are no bearings (ball, tapered, roller) inside just a thick round carbon disk which is the bearing surface.
When you grease the bearing the grease is absorbed by the carbon.
If you have split a tractor, the Cub is a piece of cake. Last time I split my Cub it took about 4 hours to split, replace the clutch, and throwout bearing, and reassemble.
Make sure the replacement is a genuine IH product not some after market piece of crap. My bad experience.
Gene
