Pulling Rims/Axle install
GordoSD
08-02-2005 21:30:49
I got the rims off. Found that a couple of real hard knocks with cold chisel and 10 lb hammer loosened them. Then got the axle housing off. Inner bearing was disintegated. New bearing from IH was 97.00 Bull gear outer surface is very uneven and had rough metal all around. Is it worthwhile smoothing this up. Should it make any contact with inner bearing races? Tomorrow will attempt to put axle assembly back in. Looks like a three man job. Two to work with axle assembly, one to reach into tran housing, align bull gear and thread bolt? Anyone done this. Is there some tips tha will help? Wish I had shimmed the bull gear where it was, before pulling the axle. BTW, stopped in at local IH dealer and got a quote for replacing axle inner bearing. Labor 5 hrs..300.00, parts 145.00 ...
