IH 464 water in oil
Farmall404
08-03-2005 06:42:21
Just got a 464 with 1800 hrs, only problem is there seems to be a little water getting into the oil. Could this be the o-rings on the bottom of the cylinders? What should I check? Where is the best place to find good o-rings? Thanks
JB2
08-03-2005 20:58:09
 Re: IH 464 water in oil in reply to Farmall404, 08-03-2005 06:42:21
Hi Farmall404, if it is a D206, 4 cylinder Diesel then it is probably leaking around the "O" rings at the bottom of the sleeves.
My Dad had this happen to his 454 D179. He was plowing with it in the farthest field from the shed and the fan belt broke so he thought he would just drive it back to the shed. Well when he got back to the shed the water temp guage was up to the red. After it got cold that fall it would leak antifreeze into the oil. Drained all the crankcase oil and left drain plug out and put a little air pressure on rad and antifreeze would drip out the crankcase drain hole.
Replaced the "O" rings and tractor is still running 15 yrs later.
JB2
El Toro
08-03-2005 07:10:33
If your 464 has a gasoline engine, I don't think that engine had sleeves. That's the 175cid engine. The 179 diesel engine does use sleeves.
If you have the gas engine it could be a head gasket leaking or a cracked head. You do not want that antifreeze in your oil. Do you see any bubbles in the radiator with engine at idle? Good indication of a problem. Hal
