Order Farmall Cub Parts Online
Long - Barn Buddy Cub Repair Costs?
N4Noel
08-03-2005 08:00:14
Hey Folks,
My last post questioned my 52 Cubs" lack of power, Well, Adjusted the gov and carb every which way but lose to no avail. Ran compressions tests to find that I had 110 psi (dry) or better to 120, 130 psi (wet) or better to 145 all the way down the line. I was very excited to find that the engine was in good shape, but still could not figure the loss of power UNTIL I got the wires for the 2nd and 3rd spark plugs confussed and tried them both ways. Turns out that the previous owner had the wires switched. She runs like a drag tractor now compared to the dog she was.
ANYHOW, now that I won"t be parting her out, I was wondering about repair costs that you all have incurred while rebuilding the lifting mechanisms/pumps and the PTO guts. The lift tends to stick and/or be jumpy, and the PTO will not stay in gear when trying to use the 42 inch Woods deck. Mows beautifully for about 20 feet then jumps out of PTO gear (not running gear).
BIG QUESTION... Will it cost me more to fix"er up than a playtoy is worth to me or should I sell it as is? What kind of costs can be associated with rebuilding the lift and PTO and can I do these jobs myself. (I have done several engine rebuilds, but have not messed with gearing or pumps.)
Thanks,
Noel
NDS
08-03-2005 12:07:25
 Re: Long - Barn Buddy Cub Repair Costs? in reply to N4Noel, 08-03-2005 08:00:14
If you are looking at repairing it as an investment SELL IT. You almost always end up with more in an old tractor than it is worth when you start to restore/repair it. Most of us look at it as a hobby and are not too concerned that there is no way to get our money back out of them.
old
08-03-2005 09:00:05
The pump system will cost the most to fix but probably not more then $500 or so. The PTO is probably not going to be to bad to fix sound like it may need a bearing or maybe a new shifter.
Bigdog
08-03-2005 08:57:56
The touch control rebuild kit is around $50 at the dealer. Good used pto parts are available at very reasonable cost. You may also be able to cure the pto issue by slotting the holes where the pto lever quadrant mounts and sliding it slightly to get the collar to engage a little further onto the shaft.
All in all, you should be able to fix everything for well under $200 and you can do it yourself. The big issue with the hydraulic unit is keeping everything clean as you re-assemble. Dirt is a killer.
