No spark from magneto
26Red
08-03-2005 09:15:12
Got a WD6 I'm trying to get going for a friend. Usually starts on gas with no problem, but I'm not getting any spark at the points. We pulled the cap off and turned the engine over to check for spark. I'm new to mags, any advice appreciated.
Michael Soldan
08-03-2005 15:05:46
 Re: No spark from magneto in reply to 26Red, 08-03-2005 09:15:12
The Cowman has the answer, anytime I have taken a mag to have it looked at, the guy cleanns the points and it fire, now I do it myself and its never failed...Mike in Exeter Ontario
El Toro
08-03-2005 10:52:58
The Cowman is probably right on those dirty points, after cleaning them, check that point gap. Should be .013" and then remove the coil wire from the cap and hold within 1/4" of good a clean ground. Have someone crank the engine with the starter and you hold the coil wire. You may want to use a pair of insulated pliers, so you don't get bitten. If you have a good spark your engine should start then. Make sure your mag isn't being grounded, not sure how, but it could be a switch. There has to be a way to shutdown
the gas engine and the mag is grounded to do this.
Hal
26Red
08-03-2005 12:59:45
 Re: No spark from magneto in reply to El Toro, 08-03-2005 10:52:58
Thanks for the help, I will try it tonight..
Nebraska Cowman
08-03-2005 09:35:34
clean the points. you should get a good blue spark out of the coil terminal on top. You won"t see a spark at the points themselves
