Order Farmall Cub Parts Online
Barn Buddy CUB- Good to Go!
N4Noel
08-04-2005 05:30:40
Hey Folks,
Thanks for the responses the other day. I had posted about repair costs for PTO and Lift Pump. With further investigation last night, my fears were elliminated. As it turns out the PTO shifter lever was bent to beat all and just took some hammering to straighten it out. Thanks Bigdog, your advice lead me to the disassembly of the lever assembly, reveling the bent lever. AND the lift pump turned out to be LOW LOW on juice. I'll do a search on what kind of fluid should be put in it. The manual specifies some kind of "IH" fluid. What ever that is. Surely there is a modern day equivelent. Anyhow, maybe I can make the Cubarama in Fredricktown, Mo. Does anyone know where I can get info on the Cubarama. It would be fun to drive it into the show. I live about 15 miles from there.
Just thought I'd share, and extend my thanks,
Noel
tn terry t
08-04-2005 19:49:18
 Re: Barn Buddy CUB- Good to Go! in reply to N4Noel, 08-04-2005 05:30:40
if you really want to get down to it the books call for 30 wt non-detergent motor oil for the belly pump
El Toro
08-04-2005 06:05:45
That IH fluid is now called Hytran, sold by your local Case/IH dealer. Hal
