Letter at the end of the serial #
Bill57
08-04-2005 12:17:14
I have an SA, Serial # 273056D. That would put it in 1949, but what does the "D" mean?
Thanks,
Bill in west-central AL
bermuda ken
08-04-2005 12:41:12
 Re: Letter at the end of the serial # in reply to Bill57, 08-04-2005 12:17:14
D represents a 5000 foot altitude attachment.
Cotton Picker
08-04-2005 12:54:18
 Re: Letter at the end of the serial # in reply to bermuda ken, 08-04-2005 12:41:12
Where can you find a listing for the letter codes?
Illinois Boy
08-04-2005 12:57:04
 Re: Letter at the end of the serial # in reply to Cotton Picker, 08-04-2005 12:54:18
The Operator's Manual for your tractor should list them in the front.
Bill57
08-04-2005 13:06:21
 Re: Letter at the end of the serial # in reply to Illinois Boy, 08-04-2005 12:57:04
The manual just mentions that the attachment consists of "a complete set of cylinder sleeves and pistons." Does this affect the way it's tuned? Should the tractor be tuned to run richer? I'm at about sea-level. Thanks a lot,
Bill
CNKS
08-04-2005 19:22:55
 Re: Letter at the end of the serial # in reply to Bill57, 08-04-2005 13:06:21
You probably don't need any adjustment. As elevation increases, power decreases. I assume the 5000 ft pistons result in more compression. Although not likely, if the tractor is fully loaded and you hear spark knock, the timing should be retarded slightly. The H my dad had (also sea level) would ping occasionally under full load, in a particularly tough spot in the field. Timing was probably off slightly. Nothing serious, just something to keep in mind. You don't do anything to the carburetor.
Nat
08-04-2005 13:10:29
The tractor should be tuned so it runs properly, period. There's no one special thing to do just because it has high-altitude pistons in it.
Bill57
08-04-2005 13:25:54
 Re: Letter at the end of the serial # in reply to Nat, 08-04-2005 13:10:29
Thank you all very much.
Cotton Picker
08-04-2005 13:00:47
I seem to have misplaced my operators manual. Haven't seen it for the LAST 50 YEARS!
Dave_Id
08-04-2005 12:56:25
Guy Fayes "IH Tractor Data Book"
jakee
08-04-2005 14:25:18
 Re: Letter at the end of the serial # in reply to Dave_Id, 08-04-2005 12:56:25
you will find the codes in the front of the model parts books.
