CLUTCH
FRANK
08-04-2005 16:35:44
I JUST BOUGHT A CUB"LOW BOY" AND THE CLUTCH IS GONE. FIRST CUB I,VE EVER OWNED SO WLL BE A NEW EXPERIENCE. I,VE BEEN TOLD THAT YOU CAN ONLY GET CLUTCH PARTS FROM CASE-INT., AND THEY ARE PRETTY HIGH. ANY FEED BACK ON PARTS OR INSTALLATION WILL BE APPRECIATED. FRANK
Roger WI
08-04-2005 20:14:11
 Re: CLUTCH in reply to FRANK, 08-04-2005 16:35:44
Frank, It depends on what you call high as parts seem to get more expensive every day. I just bought the parts for the clutch on my cub from Case IH and they were as follows:
Clutch disk - $55
Rebuilt pressure plate assy - $85
Then I had the flywheel resurfaced at NAPA - $40
Can be an expensive hobby, this tractor restoration.
Roger
FRANK
08-05-2005 06:11:58
 Re: CLUTCH in reply to Roger WI, 08-04-2005 20:14:11
ROGER, THANKS FOR THE INFO. I AM MAINLY IN TO M,S AND SM,S AND UNDERSTAND THE HIGH COST OF PARTS, BUT THE FELLOW I GOT THE CUB FROM TOLD ME THAT THE CLUTCH REPLACEMENT WOULD BE AROUND $1000.00 MAINLY DUE TO THE HIGH COST OF THE DEALER ONLY PARTS.
RickB
08-05-2005 16:36:13
 Re: CLUTCH in reply to FRANK, 08-05-2005 06:11:58
Hy-Capacity has clutch discs and pressure plates for Cubs listed. Possibly the release bearing or pilot bearing/bushing are dealer items, but surely the disc and PP are not.
